Turbo Timer?
mike.germann
Lexington Park/MD
What's up guys. I have a curious question: I know it's good to let the truck idle for a few minutes before shutting off, to let the turbo cool down. How long should I give it to cool off?
How long does a conventional turbo timer give it to cool off? If anyone has a turbo timer (or just knows), the advice would be greatly appreciated. Thanks y'all.
rammertide07
Rogersvilles, AL
I've heard after you pyro reads less than 300*
I let my truck cool down after pulling a load. In everyday operation I don't bother. Your 300° rule is valid and something I use when I cool down my turbo.
My truck has never cooled down to 300*unless the motors off. It sits at 400* at a idle.
NevrKnow
Aiken,SC
I can't see a problem with using one. I think the better ones are adjustable OR you can set it to go off with your pyrometer.
rammertide07
Rogersvilles, AL
Agreed. But the way I look at it, I can save money by sitting in my truck 2-4min and let it cool down...or spend $200+ so I could use that other time being on tv, computer, etc. Thats just my personal prefference. I know others may have the money to play around with and like the turbo timer....heck I even like it. I just dont want to spend the $$$ for it
mike.germann
Lexington Park/MD
Even when my truck has been running for a while and is at operating temps, my engine idles at a stable 300 degrees, and doesn't ever go below that until I shut it off.
What would y'all recommend? Rammertide07's suggestion of 2-4 sounds pretty close to what I do, and I definitely agree; I would rather sit for a couple minutes than spend $$$ on the part.
rammertide07
Rogersvilles, AL
Well you've done opened up the engine respiratory as much as you can...sooo....the only other thing I would suggest doing is check your coolant level and making sure the intake is cleaned out. If it would just get down to 300* and no further I wouldn't worry about it. I have a 96 F250 and I shut it off all the time without letting it cool down (I didnt know any better). The turbo has 580,000 miles on it.
NevrKnow
Aiken,SC
Your sig doesnt say anything about a chip. ( And after that list of mods I figured I would ask.)
Mine cools down ALOT quicker when I set it back to stock.
Just thought I would throw that out there incase you have a chip we don't know about.
And I'm all for the sitting there. ( I ain't rich either :lmao )
