Question Turn signal return
'57turbo
Phx,AZ
I have a '02 Crew cab and the turn signal will not return after a right hand turn but will return from a left hand turn . Will it be the turn/wiper switch or is there a return cam on the steering column shaft??
I would appreciate any insight.
Thanks, Duane
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
It might be one of the bumps on the cam lobe on the steering shaft. There are different lobes one each side of a center position, L & R.
I did a pictoral project/ post on modifying the turn signal canceling function so it wouldn't cancel the turn signal with minor steerin wheel movement ( lane changes). It was supposed to get into the wikki, but I haven't seen it yet.
In your case, it would be a good guide on how to open up the steering column and give you an idea of what to look for as a cause to your problem.
