Unusual Bolt in stabilizer kit(take a look)
A fellow Excursion owner just received his upgraded Rancho steering stabilizer for his truck today via the brown truck and it included a double ended bolt I've never seen in one of these kits,has any ya'll received the same with your stabilizer?
I know with my stabilizer kit it included the longer bolt,spacer,lock washer and nut perhaps Rancho found that double ended bolt cost less than including a separate spacer?
6LMonster
Wake Forest, NC
Well, it wasn't for running dual shocks, as one end is tapered. But, after installing, the tapered end acts as a spacer. The stabilizer works great!:sweet
Awesome!:thumbs
That new bolt included in the Rancho kit threw us both for a loop:D
The final results after installed is as expected:cool: :burnit
94f450sd
certified nutjob
plymouth,ma
that bolt is for the older chevies with the straight front axle.on the chevys steering link there is a tapered hole for that bolt to go into.you put it in tighten it up and then you put the shock on it.
Bcharrin
