bserventi
I am trying to replace the shocks on my 03 f 250. I got all of them done except the right rear.
If you look at the rear shock, the lower part of the shock has a bolt and nut that go through two tabs and the shock. The upper part of the shock mounts over a stud and is held in place with a nut. The previous owner must have stripped out the nut when putting the shocks on, now I cant remove the nut to get the shock off.
Any suggestions on how to get the stripped nut off the stud, and what to do when I get it off to mount the new shock on if the threads are trashed .
