Usable Grommet on Firewall?
SeventyMach1
North Carolina
Doing an amp install. I can't find anywhere on the firewall to run the power wire. Any suggestions?
Also, since they both read 12V, I suppose it doesn't matter which battery I tap it to, right?
i know that in my 2004, there is a big grommet in the floor close to the go fast pedal. i have used it to run wiring for lights, airline, etc.
just cut a small hole into it and you could a thick double sided tape or silicone to seal it up when your done.
Tbar
SDD STAFF/Moderator
Will your amps be behind the rear seat???
I ran some power through the rear vents, under the chasis and up to the battery. Every thing was in loom to prevent chaffing.
Tbar
Tbar
yep, i would say that is one way to do it too:eek:
SeventyMach1
North Carolina
Haha .... thanks for the help guys. I ended up getting pissed after looking for an hour and drilled a hole in the firewall. I'll have to go back and get a grommet to slap in there, though.
SeventyMach1
North Carolina
Next question.
How do you install an amp with the factory HU? Is there a harness-to-RCA convertor that I can buy? Oh ..... and I have a place on my amp that says "SYSTEM WIRE". What wire should I be splicing that to?
