Wannabe 6.0 gauge whore...
ponyexpress94
Diesel Power Junkie
Maryland
As the title implies I am looking into putting gauges in my 03 6.0L and I am looking for input on where to hook up some of the sensors.
My wish list of gauges:
Oil Pressure
Oil Temperature
Water Temperature
Fuel Pressure
Boost
EGT (Pre and Post Turbo?)
Trans Temp
I have located one or two articles describing fuel pressure hookup and coolant temp but I wasn't sure I should be putting a coolant sensor in one of the blocks drain plugs. I want to keep my factory gauges working so I am curious if I can insert adapters at various locations to insert an aftermarket sensor without adversely effecting the stock sensors reliability or it's readings which may go to the ECM for operation of the engine. Any help would be greatly appreciated. Thanks in advance.
ponyexpress94
Diesel Power Junkie
Maryland
thanks for the help treyloco. Does anyone have suggestions for the oil pressure and oil temperature senders?
