i am not sure what/how you are doing thisbut i don't think that you are going to find out anything like that. and i would not force the turbo to spin without any oil pressure to lube the bearings.
unless you KNOW that you are suffering from low boost its jousting at windmills. if you have low boost then you have a leak from somewhere.
check the boots on the IC pipes, there are 4 of them, the sheet metal intakes there are 2 of them, your turbo, the IC, etc..
you already said that you have an exhaust leak, start with that. the truck will NOT make boost unless it is working hard. like pulling a trailer uphill.
DO NOT mess with the wastegate pushrod adjustment. it will not change the boost pressure, only the blow off pressure.
make sure you understand how the turbo works and what the function of each of the components are before you mess with things.
these pages are pretty good:
Wastegate - Wikipedia, the free encyclopedia
Turbocharger - Wikipedia, the free encyclopedia
and look at the ford diesel tech society webpage for a coffee table book pdf on the turbocharger.
