Water Probe Power
roosterdiesel
Earl needs B100
Amarillo,TX
I need a point to get power for the water detection module of my Racor 900FH.
The module draws 3 milliamp. The schematic shows it needs to be switched and have a 1amp fuse inline. Will the 10amp circuit that my pyro gauge is tied into ok or is there a better choice.-popcorn
:thanks IA
Wood County Tx
how much does the pyro pull? mine is 0,
but i would think it is no where near 5 amps, so you should be fine,
the water detector is just a sensing element, water completes the circuit to give you a warning lamp, the lamp is the where most of the current is used.
the thread name makes you wonder if this is a medical procedure:D
whatabudro
Launched
Should be good. There are also some customer access wires to the passenger side of the go pedal if you haven't used them already.
