water temp probe
Tx_Atty
Master Baiter
Fishin'
I am trying to install my water temp gauge. The plug in the water pump will NOT break free no matter what I do. I have put a box end wrench on it and used a 2 foot stake and hammer to no avail. Can anyone tell me how to get the (*&$(*@#&$## thing loose???
Thanks!
dpantazis
#12
under the cheddar curtain
did you drain the coolant yet?
kroil or PB Blaster and a little bit of heat to the water pump boss.
need to get the coolant out to get it hotter than engine temps or you will just heat the water.
Tx_Atty
Master Baiter
Fishin'
Cute Richard. :tounge
I did not drain any of hte coolant. I had hoped (what was I thinking?) that I could go out and just break it free and see if I needed to drain any to avoid dripping from the plug hole. I havent driven it since I got home from work yesterday so I figured it should be fairly easy. There I go thinking again.
Other than engine heat, I dont see any feasible way I could get it hot. I dont have, nor am I willing to try, a torch.
I think Tbar is at the mod day I couldnt attend today.
hheynow
Señor Aceite de Soja
Northern California
Peter when that plug is removed coolant will drip. Have a large catch basin in place. That's where my dieselsite coolant filter gets coolant from and returns it to the degas bottle ( I added a brass tee ). In that loop is my coolant temp sensor for my water gauge. I really see 200-204*F when fully warm with dieselsite's 203*F t-stat.
atk
Moderator
simcoe, ontario, canada
you can try giving it a good hit with a hammer or hammer and punch....the shock from the hit might free it up some or you may have too use some external heat(torch with brazing tip)...hope this helps
Tx_Atty
Master Baiter
Fishin'
Richard, how did you get it loose? I figured I might need a pan but was waiting to get it loose first. I have the same 203 thermo.
Tbar
SDD STAFF/Moderator
Hose it good with a good penetrating oil and repeat over several days.........then try getting a cheeter bar on it and strike with a hammer.
This isn't the T-Stat plug I am removing but it will give you an idea anyway........
Thermostat plug is just above it in the picture.
Tbar
