What Gears?
cemily
Columbus, IN
is the truck stock height and tires., what is the year and
single axles came with 3.73 duallys had 4.10
if it is lifted it may have been regeared..
a 32" tire and 4.30s would be turning 2000 rpm at 60
It is stock height and stock tires. It is a 2000 F350 6 speed
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
I have 285/75x16 tires, automatic tranny & 3.73 ratio.
I'll turn 2000 rpm @ 67 GPS verifed MPH .
and i would bet its a completely open set...the early
trucks didnt <commonly> come w/ 3.73 limited slips.
02stroker
Gratz, Pennsylvania
I have a 2002 250 with a 7.3L 6-speed and I turn 2000rpm @ 70 mph in overdrive with a 3.73 rear.
Doghead
Cobblehill, BC
The definative way to figure this out would to open the diff count the teeth on the ring gear and the teeth on the pinion then divide the number of teeth on the ring by the number on the pinion and thats your gear ratio
