What Happened
Tcat
Tcat-F350
Bryon, Ca
I was shimming the FPR spring this morning and had put it back to together and had 87 psi on the fuel pressure guage. so I removed the cover again and removed one washer! I started with Three, I relaced ever thing back together and now I have no fuel Pressure at all . I took it back apart and notice that the spring was gone. So I removed the cap and found the spring inside the pipe. Question!!! Inside the cap is there a retainer that keeps the spring in place.
dpantazis
#12
under the cheddar curtain
its part fo the casting
the 'retainer' is part fo the casting- there is no pic in the wiki page-
look at the Y shaped part of the casting. the spring bears against it.
i clipped this pic from the install instructions from dieselinnovations.
there are better picture of it here in these pages
http://www.dieselinnovations.com/techfiles/shim_kit_install_instructions.pdf
you may need to get the kit from DI if you broke the pot metal casting. its cheaper than dealer :(
i hope you didn;t break it, truck won't run w/o it. its crap pot metal.
Tcat
Tcat-F350
Bryon, Ca
I See that has broken and I have called ford and they said that the will be 45.00 dollars. may be next thursday. Also I thank you for the link as soon as I seen the Pic's I knew that I was not driving the truck for a while . Unless somebody knows a quick fix. I was going to make an x and set it in there so that I can At least move the truck
roosterdiesel
Earl needs B100
Amarillo,TX
I have the factory reg. housing and a DI one that I no longer use. If you want the stocker I'll depart with it cheap! :D
Tcat
Tcat-F350
Bryon, Ca
Thanks roosterdiesel. I am going to order a DI on Tuesday.I have made an Adapter so that I can move the truck.
roosterdiesel
Earl needs B100
Amarillo,TX
I'd depart with the DI one for a little more, I just thought you were going with another stocker.
Tcat
Tcat-F350
Bryon, Ca
Roosterdiesel, Send me an e-mail and tell me how much for the DI
