what is this?
john griffin
starvation lake,michigan
OK,this is the thermostat that senses oil temp and engages the flapper ? I pulled it out and it looks like it will have to stay in the pedistal.So, do I plug it back in or leave it unplugged? Also ,my 16 yr old turbo assenbly bolts are not looking too good but I cant find a fastener (bolt) kit anywhwere so it looks like I'm off to the fastener supply house in the morning.
79jasper
El Paso, TX
Look up ebpv delete. You'll find instructions on how to delete it.
john griffin
I did look up the delete. It seems that most people just buy the pedistal that doesnt have it and if I had time thats what I'd do.A couple guys just un plug it and leave it so I guess thats my plan.
79jasper
El Paso, TX
No, let me find one with pics.
There was one recently updated with pics.
Basically you need a few freeze plugs or pipe plugs.
john griffin
In the "gut & plug thread There was a pic from a guy that filled the sensor hole with JB Weld,then put the retainer clip back on. Why not do the same with the actuater houseing & This would seal the ports without welding.
79jasper
El Paso, TX
Well you could.
I tapped mine and used pipe plugs.
79jasper
El Paso, TX
The ports inside where the actuator goes, I drilled them out slightly and drove in a BB. (Iirc)
I don't remember doing anything with the hole the "sensor" (which is actually more like the ipr by function) is in. Can't remember why I didn't. I know I left the stem and Solenoid. I just cut the wires off.
Where the actuator rod comes through I put a pipe plug.
On the valve it self I removed it completely and used pipe plugs, as I'd heard of issues using freeze plugs.
Of course mine is slightly different being a obs, but it's the same principle.
You could just leave everything in place, and unplug it until you can just buy the delete pedestal.
