What parts do I need when replacing injectors and glow plugs?
f100cleveland
When In Doubt,THROTTLE ON
Southern Minnesota
I'm gonna replace the injectors in my 2001 with a set of 50hp split shots. When replacing injectors, might as well do the glow plugs too. But what are all the harnesses I need? I know I need the valve cover gaskets and injector harness. But is there anything else? Does anyone have the Ford or International numbers for the gaskets and harnesses I need?
valve cover gaskets/injector/glow plug harnesses are re-useable.
Good thing, they're like $130. bucks per side...
f100cleveland
Southern Minnesota
I've heard stories that its best to replace the harnesses when doing the glow plugs and injectors, but maybe they are just stories???? Has anyone replaced the harness or vc gaskets when doing the above work?
BigDaveZJ
uber noob
Castle Rock, CO
If you're digging in that far, I would at least put the little clips on the UVC harnesses that Ford makes to keep those from coming unplugged.
john_hughes
I am doing the same. I changed the UVC Harness because they are know form going out. Also good idea to change the plugs.
JonH
Here are some P/Ns if....
you haven't already found them.
Retainer (Under Valve Cover Harness clips)
Ford 2C3Z-14A163-AB
Int’l 1844193C91
Wiring Harness, Injectors & glow plugs
Ford F81Z-9D930-AB
Int’l 1830844C93
Valve Cover Gasket
Ford ???
Int'l 1826703C1
Usually, International is maybe 1/3 the cost of Ford. So I don't need to tell you which place to go.
Hope this helps,
Jon in American Fork
f100cleveland
Southern Minnesota
Thanks for all the replys guys. I'd feel more comfortable replacing the harnesses too. Also, thanks JonH, those numbers will come in very handy since I haven't found them yet.
