What's on your "wish list" of mods to do?
I was thinking about making a "wish list" of mods I would like to do in the near future to my truck. It will be paid for in about 6 months and the mod bug is starting to Knaw away at me again.
So here is my list of 5 mod wishes I would like to do.
1. SCT livewire (to eliminate the A-pillar gauges) with custom tunes.
2. Stacks with no muffler or CAT.
3. Complete the front end to the '05 look.
4. 2008 center floor console
5. Get my door handles, tailgate handles, and tailgate repainted (starting to show some wear & tear.
So put up your "wish lists" of future mods you would like to do.
It doesn't matter if it's for your OBS, Excursion, 7.3, 6.0, IDI, etc.
Maxtor
Redding
Good question.
1. Wait until warranty runs out and install the best power adder at that time. I only use our truck to pull the 5th wheel, and later on will use it to pull our race car trailer, so the only need we have is for towing power. We ordered our truck from the factory with all the features we wanted, and after delivery we added mud flaps, rhino lining, 5th wheel hitch, 5th wheel tail gate, and axillary fuel tank, so we do not need to add anything else. Right now, it sits there looking lonely until it is needed again.
W code springs
New shocks
Front sway bar links
08 differential cover
Troy Console
New XM Receiver
Jimmi Jammers
Vehicle Security System(still):rolleyes:
architect-builder
Jerome, Idaho
My Master List, (still adding though) :sly
Completed:
Goodyear Wrangler 285 MTR Tires-Done
X Springs Leveling Kit-Done
DPPI 4” Dual Exhaust w/ slash cut tips-Done
Edge Juice w/Attitude and under handle piller mount-Done
ISSOPRO Guages w/ underdash housing-Done
On Board Air w/ VIAIR 550C Compressor and 5 Gallon Tank-Done
Under Cab Air Horns-Done
Quick disconnect air fittings under rear bumper-Done
Clear Clearance Lights-Done
Running Board LED's-Done
Auxiliary Reverse Lights-Done
Billet Badges-Done
International VT-365 Domed Badges-Done
Magellan Meridian GPS-Done
DVD w/ Overhead Screen-Done
Excursion Console w/ rear cup holders and stereo controls-Done
MagLight next to the drivers and passenger seats-Done
Rechargeable Pelican “Big Ed” Light mounted on trans hump –Done
DEE-ZEE Aluminum Truck Box – Done and Full
Fire Axe w/ fiberglass Handle, 60” High Lift Jack, Shovel and Prybar mounted to Truck Box-Done
(2) Aluminum diamond tread behind the wheel truck boxes w/ drawers-Done and Full
5 and 10# Fire extinguishers mounted on either side of the behind the wheel Truck Boxes-Done
Thule "Bedrack" w/ bike and ladder attachments-Done
24" Silicone Wipers-Done
Crome Bug Shield-Done
2005/6/7 front end upgrade-Done
GOS headlight upgrade harness-Done
SilverStars-Done
Warn 16.5ti Winch-Done
Warn SS Transformer-Done
Chrome Tow Hooks-Done
Undercab security lights-Done
(4) KC Highlighter 100 Watt driving lights-Done
Whelen 90 Watt Power Supply and Strobes in headlights, taillights and rear cab light-Done
Red Overhead LED Bar Light-Done
Red Below Mirror Dash Light-Done
Red LED Lights in Grille, and on corners of front end-Done
Split Red / Amber LED lights, rear facing on truck box-Done
Galls 6 Switch Warning Light Control Box-Done
Wish List:
Wheels (Still trying to choose a style)
ARP Studs and Head Gaskets (Sure I’m going to need them eventually)
ATS Torque Converter
SCT??????
Move gauges to above mirror mount, add more gauges in existing location
Hookup the stereo controls on the rear of Excursion Console
1500 Watt Inverter w/ Auxillary Control Switch
12 Circuit Fuse Block w/ waterproof housing (to clean up wiring under hood)
Working interior lights on the door trim front and rear
Lockable underbed 6" PVC storage cylinders
12V outlets under the hood and in the bed in waterproof housings
110v waterproof outlet in the bed
12v lid activated lights in the console
12v lid activated lights in the truck box
Marine Speakers in the bed (for drive in movies)
Dual stainless steel 5 gallon air tanks mounted under truck box on ends
Power tail gate lock
Bilstein shocks
Rancho front end stabilizer
F&R Helwig anti sway bars
MagHytec differential cover with syn fluid added
Extendo Bed cargo platform w/ water proof enclosures, (for my fire gear to get if off back seat).
Man, I need a shop!!!! :eek:
Barrett
dboyw
Lancaster, PA
1. Finish paying truck off, followed right by #2
2. BTS TRANS!!!
3. DP Tuner right after trans upgrade
4. 2008 Tow Mirrors
5. Reg Return Kit
6. Complete Engine Rebuild with goodies.
F350DRW1
Waylon Fan
N.J.
My truck is right where I want it. Too bad the injectors and glow plugs aren't. Its either a plunge for those items [ $$$:doh:] or get a new one. And start all over again. :lmao
RoyBoy
Diesel Dork
central WI
1. Get my regulated return fuel system/ fuel pressure gauge/ lower gauge pod installed.
2. Remove and polish wheels, reinstall. (wash the truck too)
3. Head studs and gaskets (once the puking gets a little worse)
4. Replace my mystery clutch once it leaves me stranded :D
Of course that all will be once this backlog of work disappears :rolleyes:
