Wheel Bearings
happeetxn
9/11 Never Forget
Dallas
Howdy All,
I have my front driver side rotor off right now and I assume that it has inner and outter bearings right? I ask because the "bearings" on the inside of the rotor that slide up on the spindle has a HUGE amount of play in it. I believe that it is pressed in, so how do I get it out? Also the wheel had some play in it from side to side, I can't tell you how much like in inches, but enough for me to be concerned. Aside from new bearings what else do I need to look at?
Thanks,
Craig
Big K
SDD.com Hacker/Admin
Dallas, Texas
Craig,
Not sure if the 2wd are the same or not, but the 4wd isn't pressed in, it has a SEAL on the back side that will need to be removed and replaced.
Also, is the play in the balljoint or steering? or is it in the bearings?
happeetxn
9/11 Never Forget
Dallas
Hey Kevin,
The Ball Joints were repaced in Dec 05 - Jan 06. I can't say if the movement was from the steering or the bearings, but the bearings have over 100K on them, if that makes a difference. Autozone said that they don't list a part number for outter bearings. Can that be right? I told them it is a Timken 15101, they say that is a cone of some kind.
Craig
