Which Transmission Pan?
TomsKingRanch
Norwich, CT
:dunno Been reading posts and looking at ads for aftermarket transmisson pan when I tow my 7k camper with my 07 6L F350 King Ranch. Anyone have any comments on which pan I should consider or even if it's really needed?
Leaning towards the PML as the cost is less than the Hytec and seems to be about the same. Thanks
do you have a trans temp gauge ? (other than the pos that ford put
in the dash?) unless youre running HOT i wouldnt bother.
make SURE youre changing the factory supplied trans by-pass filter
(mounted up front under the radiators on the passenger side)
and make sure youre FLUSHING the fluid at the intervals required...
DO NOT USE FLUID OTHER THAN MERCON SP
MOST independant shops <dont know what mercon sp is>
they dont keep it in stock and they would have to have a sep.
machine w/ it in for flushing.
mercon or mercon V is NOT ACCEPTABLE transmission fluid for the 6.0
torq-shift automatic.
if anything you might wanna consider the move to the fin'd 2008 rear
diff...doesnt add any capacity but it will add some cooling (and look
nice)...it wont rust either...and its 4+ times LESS (cost) than a
mag-hytec
check my links for info on the trans gauge (and why the factory supplied
unit sux).
ive got links in there to the rear-diff cover.
you can flush the trans in your driveway if you follow the directions
(like i did) --> Truckblog - How-To Flush Ford's Torqueshift Transmission
youll need about 22quarts of mercon SP.
jwplunkett
Colfax NC
Which Transmission Pan ?
Just this evening changed factory transmission pan to Mag-Hytec
Also purchased Mercon SP from local Ford Dealership -- been thru the exercise of whether to use Motorcraft Mercon SP or Synthetic --- I decided to stay with Mercon SP for Warranty.
Draining the factory Pan oil and replacing Tran pan with Mag-Hytec was a breeze
I have a 2006 F250 FX4 Diesel 6.0 - Automatic Trans
Now for my question: Haynes manual states to drain the Torque converter for a total transmission oil change ---- so I located the nice handy Factory Rubber grommet bottom front of Transmission and then marked with a grease pencil as my starting reference point --- then manually rotated the engine with wrench on pulley and went full circle and didn't locate the Torque Converter Drain Plug --- Now I viewed several bolts that I assumed held the torque converter cover .
Can some one help me understand / procedure for draining Torque converter --- I truly desire to do a quality job and replace all Transmission fluid.
Maybe I should remove anyone of the bolts I viewed as engine was manually being rotated --- would that let the fluid drain from Torque Converter ?
Your experience / guidance is most appreciated and needed :oops:)
John from Colfax NC
jwplunkett
Colfax NC
UPDATE 1 --- My Ford Model Yr 2006 F250 FX4 Diesel 6.0 is equipped with the 5R110 Auto Transmission.
Requesting please procedure to change Torque Converter fluid so I will have 100% fluid change
Many thanks in advance
John from Colfax NC
john...did you read my post...w/ the links ???
you can perform an entire system FLUSH (in your driveway)
by following the link i provided in earlier flush !
jwplunkett
Colfax NC
Outstanding BushPilot and many thanks ---
To locate your earlier web link ---- do I search on your name ? ---- or on some other key word ---- still learning all the features of the forum member page
Please advise and happy upcoming holidays to all
And if traveling safe travels
John from Colfax NC
jwplunkett
Colfax NC
Which Tranmission Pan ? - Torque Conv Drain Procedure - 5R110 Auto Tran
Hello Bushpilot / all ---- many thanks and truly don't desire to wear you out
But I went to the web link you provided and it had GREAT info on Block Heater ( 3 Pages )
I scrolled thru all pages searching for Torque Converter drain procedure but didn't view same - Ford 250 Model Yr 2006 equipped with 5R110 Auto Tran
Don't give up on me :oops:)
Thanks as always
John from Colfax NC
read THIS --> How-To Flush Ford's Torqueshift (5R110) Transmission <-- and follow
the directions for a COMPLETE transmission FLUSH !
the factory torque converter doesnt have a drain in it !
how many miles on that truck of yours anyway ?
have you changed the transmission by-pass filter ?
did you replace the filter in the pan when you dropped the pan ?
