which water pump ? ?
foxman
Upatoi, Georgia
Need to replace water pump on 95 PSD 7.3. Which is the better choice, the International or the Ford? I have read several posts on this but still nothing real clear. Please help?
Foxman
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
Use the Ford unit.
Supposedly IH & Ford use different pumps on the same engine.
The different water pumps also means different t-stat housings and IIRC, different radiator hose outlet.
one of the upgrades that has been done previously is the international water pump with the integrated coolant filter. This is not as easy as a bolt on deal and is expensive because you have no core and you need to buy a coupler idler pulleys from international and a longer belt.
I am just running the standard OE replacement, mine happens to be from autozone since I needed it and no body else had one on the shelf.
