Help Needed Who is still running a 7.3 with a chip?
Whose tunes are you running?
  • PHP
    Votes: 0 0.0%
  • Gearhead
    Votes: 0 0.0%
  • custom/other (list in reply)
    Votes: 1 100.0%
  • Total voters
  • Poll closed .
Replaced my F5 chip with a Hydra..
Need a couple tunes PHP didn't offer.. no start and a higher high idle..
available for other PCM calibrations, just not mine..
What/Whose tunes are you running?
02Oilburner
SDD Power Hungry
Raleigh, NC
Im still running my F6 DP tuner. Tunes are: Stock, 60hp tow, 80hp economy, 100hp performance, 120hp race, 140hp extreme
79jasper
El Paso, TX
Uhm, yes they do.
No start is built in.
I have high idle in 1000, 1100, 1200, 1300, 1400, 1500.
What pcm do you have?
Sent from my *******-SM-G890A using Tapatalk
my no start is a stock..
so it goes stock, stock, 40 tow, 80 daily, 1100 hi idle..
hex code for my PCM is VJAE3U5
I got it..
I saw No Start tunes listed for other HEX codes, assumed it was one you had to program into the chip..
you just keep flipping until you run out of flashed tunes, then next one comes up "nS" and you shut the truck off.
much easier when you watch the video..
I still heard someone say they get better fuel economy on the GearHead daily driver tune, so that was the other issue that prompted me to
ASK QUESTIONS!
79jasper
El Paso, TX
Vraa6s3 is the hex code in the tune library you need to look for.
You have way more tunes available for yours than I do mine. You have 56 tunes to pick from.
What specifically are you looking for?
79jasper
El Paso, TX
Here's all of them.
79jasper
El Paso, TX
Oh yeah.
You can dim the switch also. Use the up and down buttons. Push and hold for about a second then let off.
79jasper
El Paso, TX
That's what it gave me when I punched in your hex code.
