Scot
I have a 6000 watt Deere generator I use daily for work. It has issues starting a simple 1 hp stacked tank air compressor. On colder days I need to completely drain down the tank on the Air to get the compressor to kick over. After it starts once and gets warm, it's fine. The only manufacturer that seems to have a 110/220 setting switch is Honda. This feature allows ALL the starting power from the generator to be sent to a single 110 outlet. Normally the starting power is split between 2 - 110's.
I'm trying to avoid buying the Honda, cuz of the insane cost & lack of funds from business being down.
Would A compressor that can be wired for 110 or 220 correct my problem without replacing the generator? My thinking is if the Comp was pulling 1/2 load from each hot leg it should have the same effect as the switch on the Honda.
Anyone have a clue? Or at least more than I do???
