twt
I have a intermittent miss that is worse with a heavy dew. I have put in new injectors $$, new torque converter $$. This problem is at low rpm & little throttle about 2 to 5 psi boost. I think there is a module under the left fender that converts 12 volts to 140 volts dc could it be at fault? Has anyone had a problem like ths or am I the lucky one? One shop wants to do a compression test then take the motor out to check the camshaft$$$. Any thoughts & suggestions will be appreciated.
