will a motor out of a school bus work
pawsranch3
oklahoma
i have access to a lower mileage 7.3 powerstroke motor out of a school bus. this motor is currently in a pickup truck with a bad transmission but the owner said that i can have it. will this work in my 2000 psd
Wingdog
Thunder Bay, Ontario
If it is a 7.3L powerstroke it will fit just fine. I don't imagine they made the bell housing mounts any different for a bus. He already has it in a truck so it should go back in one. :sweet
do the years matter? or as long as it is a 7.3 powerstroke will it work
the '99 - '01's are reputed to be the stronger engines... there is a known serial number split where they went to "powdered metal" rods instead of forged, and they are allegedely "blow up" prone..
pawsranch3
oklahoma
but if this is a 94.5- 97 7.3 powerstroke will it work in my 2000, i am not too sure what year this schoolbus was
man if youre gonna do this consider installing a new oil pan or at least
inspect the hell outta the existing one....theyre rust <thru> prone...
and the only way to replace 'em is to pull the engine.
pawsranch3
oklahoma
this motor is out of a schoolbus that is sitting over at my friends house the but has less than 100k miles on it and has been maintained by the local mech. here in town. i dont know the year until tomorrow but if it is a 94.5- 97 will it still work?
94f450sd
certified nutjob
plymouth,ma
any year powerstroke will fit.just have to change certain parts.
comeing from a bus you will need to swap the oil pan,flywheel,trans adapter,exhaust manifolds/uppipes,possibly the oil cooler,HPOP reservoir,water pump unless you read the directions on converting your truck to run the IH pump with the coolant filter,bottom pully and all accessories and brackets.possibly the turbo or the compressor housing and intake Y pipe.and some sensors here and there as well as the passengers side valve cover.
