Winter is approaching fast!
SDEric
Here's my pride!
MD
With that said, I would like to see what our members do to prepare.
I might have overlooked something that someone else thinks is necessary -popcorn , you know for peace of mind.
Thanks
I make sure the coolant level is in normal operating range,the grille cover is in the truck and I inspect the Block/Oil Preheaters for any cord breaks & they are working normally. :)
Test batteries, check coolant freeze protection, give the fuel a little shot of Howes to remove any water in tank and clean out the shop and garage to make room for the rigs inside. As far as the peace of mind, there is not any at -50º
hheynow
Señor Aceite de Soja
Northern California
Dayum! If we see a cold snap that'll mean four days at +22*F once during the season. Personally, I do nothing special for my truck during the winter time (I use Stanadyne year round). Our winter weather here is rain not snow.
redpsd
not zactly sure?
change oil out to 10w-30, fill up my little containers with Powerservice for fill-ups, and as stated before...check all important cords for no fraying or breaks. Put the winter survival kit in the truck behind the seat(candy bars, blankets, papertowels, matches, coffee can, chit like that).
red
runnindiesel
yeppers....
texas
man the coldest its been here in my part of texas so far is like 55 and my batteries already had to be replaced so i had to spend big money and get those today
Thanks
Check yer Tire pressure(s). there can be a 10lb diff from summer to winter. Check yer windshield wiper blades... out west they prolly been sit'n on the W/shield for 3-4 months.... all Dried up. Get yer chains out, spray'm with WD-40, and look at yer tensioners. Gloves. Mat/tarp to lay on while chain'n up. Pliers. Wire. Small shovel. Tow strap. Flares. Batteries in yer flashlight. First-aid kit.
Check all the fluid levels..... Battery connections, spare fuses. Funny you should mention this.... I just did all this yesterday, on my SD and the wifes WindStar.
Kinda gives me a "Warm'n Fuzzy" know'n I'm (We're) Ready. ;) :) :sweet
