wont start easy
99SD
Belleville,IL
ok my truck takes a long time to start. i replaced my glow plugs and the relay. what else could it be??? i have good fuel pressure to. let me know if you can help me trouble shoot this problem.
99SD
Belleville,IL
about two months old. i work at an international dealer in st. louis and one of the techs said he thinks it is the injector o-rings leaking.
whatabudro
Launched
I had a 6 month old optima fail a load test. They are free at most car parts stores and cheaper/easier than labor on o-rings r&r.
99SD
Belleville,IL
found the problem. it was the inj. o-ring on the passenger side last cylinder. one ring was ripped. the tech at me work said that one was bad and he was right. i was lucky it was the side i took apart. thanks for the help anyway.
Derrick
tko5o
Simular problems
I'm having simular problems, did it run alright once it was started? any other side effects? I'm getting very high fuel pressure during cranking until it starts.
Anybody have any Ideas?
