Won't start strange symptoms??
BobGrady
Blythe, Ca
3 weeks ago my I started my truck as normal. It ran for about 1/2 second and died. Idiot lights work on dash as normal, but dead. When I tried restarting it was dead. Dash lights came on but no crank or click or anything.
After letting it sit for a couple of hours... I tried to start it. It started but the starter stayed engaged. I shut it off. After that it started and ran okay.
2 weeks ago it did the same thing. Start, died, then nothing. After letting it sit... same thing started but starter stayed engaged until I shut it down. Then normal.
Took it to dealer who kept it over a week. They replaced a high pressure pump and said they found a short to the fuel pump. Assured me this fit the symptoms and was now fixed.
Today It started, ran about 1/2 second and died...gonna try again in a while.
Before the 2 1/2 hour drive to dealer, Any ideas?
iracemine
black and tan
Cheese Curtain
Doesent this engine suffer from hydro lock problems? And because of that the starters get damaged (since the coolant poors into cylinder 8 after the engine is shut off)? Maybe your truck is having the start of this. Like its slowly starting to happen. Have your dealer check the compression on all 8 cylinders :dunno
