WOOOOOOOO HOOOOOOOOOO!!!!!!!!
ryanPSD
Living in Kallynogunforya
No
Oohhh that's right I totally forgot about your injector problems! Cool dude I hope you get it sorted out, sounds like there is light at the end of the tunnel.
Oh yeah, let me know if you ever upgrade injectors. :D
94f450sd
certified nutjob
plymouth,ma
well as usual my life and luck suck.i got one injector messing with me.but beans got a replacement on its way to me:sweet
94f450sd
certified nutjob
plymouth,ma
yup it had a skip,low power off the line,stalling.i did multiple contribution tests and it kept coming up with cylinder 3 contribution/balance fault.so i swapped #3 with #5 and now it says cylinder 5 contribution/balance fault.
rickh
Biodiesel Rules!
Bellevue Nerbaska
Well Rich, perfection aint easy! You will get there and have a good time doing it!
Let us know if that fixes it, and if it does, let us know when you put the rod through the block. Not trying to jinx you are anything! :)
Rick H...
94f450sd
certified nutjob
plymouth,ma
well surprisingly im not haveing an issue with the cylinder that lost a chunk of the nozzle so i dont think ill be putting a window in the block.
ryanPSD
No
94f450sd said:
has about 70 15 second passes at the track,a few videos,countless smoke shows,and gettin the crap kicked out of it everyday.
All on the same stock turbo? That thing aint blown up yet???
