Help Needed no start
buckhunter
Blakely Ga
Hello to everyone
I have a 2006 ford f 250 i was driving down i 10 about 75 mph when i lost all power like it ran out of fuel and now will not start all help is needed
A/Ox4
Ventura, CA
Will it crank? Does it smoke when cranking?
Check oil level to start. Is your fuel above 1/4?
:welcome to SDD. We all will try to get you going. First, how many miles does the truck have on the clock? Have you owned the truck since new?
Dave ;tu
Have you had the FICM (Fuel Injector Control Module) replaced? I had mine changed at about the same miles as you have. There is a check you can do to see if the FICM is good or bad, but I don't remember what it is. Maybe someone will chime in and tell us. You need to have these trucks scanned anytime you have a problem or you end up throwing parts at it. Good Luck!
Dave :)
buckhunter
Blakely Ga
I put the ficm in and still no start now they said to look at the oil pressure to low thats my next challenge
It sound like you still have a good amount of air in the system. But there are two fuel pumps on these trucks. I don't remember if the back fuel pump is on the rail or in the tank but have you checked it? This one is a low PSI push pump. It push's the fuel to the HPOP which fires the inj. Also check the fuel pump relays and fuses.
