Help Needed no start
buckhunter
Blakely Ga
Hello to everyone
I have a 2006 ford f 250 i was driving down i 10 about 75 mph when i lost all power like it ran out of fuel and now will not start all help is needed
A/Ox4
Ventura, CA
Will it crank? Does it smoke when cranking?
Check oil level to start. Is your fuel above 1/4?
:welcome to SDD. We all will try to get you going. First, how many miles does the truck have on the clock? Have you owned the truck since new?
Dave ;tu
Have you had the FICM (Fuel Injector Control Module) replaced? I had mine changed at about the same miles as you have. There is a check you can do to see if the FICM is good or bad, but I don't remember what it is. Maybe someone will chime in and tell us. You need to have these trucks scanned anytime you have a problem or you end up throwing parts at it. Good Luck!
Dave :)
buckhunter
Blakely Ga
I put the ficm in and still no start now they said to look at the oil pressure to low thats my next challenge
Dogman
tampa,FL
It sound like you still have a good amount of air in the system. But there are two fuel pumps on these trucks. I don't remember if the back fuel pump is on the rail or in the tank but have you checked it? This one is a low PSI push pump. It push's the fuel to the HPOP which fires the inj. Also check the fuel pump relays and fuses.
