Question 03 6L quite again
butch2000
michigan
Ok , so had this probelm about 3 weeks ago , truck just quit ? found it was a bad FICM , had it rebuilt , and today it quit again , blown FICM fuse ? wtf is going on ?? any feedback would be great !!! where should I start to look ?
You will need to take your truck in for a good mechanic to scan it. Everything else is guessing on these computer controlled trucks.
Dave :dunno
butch2000
michigan
Ok , had it scanned out this morning nothing shows up , the fuse it blow was the Engine control fuse ? #22, so what could cause this to happen , were should I start to look ? any idea's ?
Tell us more about your truck. Do you have any modifications like a tuner or chip? New car stereo or some other electronic devices? :dunno
Dave :)
butch2000
michigan
Have a Banks 6 gun programmer , and after market stereo, and Banks exhaust , that's it ,
butch2000
michigan
Is there a trouble code list here somewhere ? can not seem to find it ? for the 03 6L
Yes the DTC (Diagnostic Trouble Codes) can be found in the WIKI Technical Articles section in the top BLUE LINE. Scroll down until you see the DTC codes. Sorry, on edit, I don't see them. This is a new version of vBulletin and not the final version.
butch2000
michigan
replaced fuse #22 , seems to be ok , run all day , does anyone know what runs off this fuse ? when it blow truck would not even turn over ?
Remove the Banks 6 Gun and try it out. Check the normal things, like oil level in the engine, fuel filters.
Dave...
