'05 Level Lift
RandyH
Western Colorado
What's everyone using for a front level lift on their '05 F350's? I want to do the 2.5" lift to make it sit better. I'd be interested in hearing the pros and cons of the polyurethane vs aluminum coil spacers that I've been seeing. The polyurethane seem to run from about $150 and higher but I've seen the aluminum for 1/2 that. I'm only interested in the ones that bolt on under the coil, not at the top. I understand that I'll also need to replace my front shocks with this lift. Any experiences with these lifts either good or bad? Thanks.
missingsc331
new kent virginia
i have the same truck and vs putting some block in there, i called rough country and ordered a set of the 3in lift springs. i want to say that the were only about $130 for both ... the ride is still good and i didnt change the shocks. i would recommend my set up over the others ... good luck
