Question 12v wiring question
What are you going to power up Bama ?
I just thought it would be a good thing to have a 12v outlet handy for charging a Dewalt drill, or a cell phone (if working outside and it needs charging) a small heater for those cold camp outs, etc.
Just an outlet to use any 12v accessory.
bbressler
Happy, TX
How about next to your trailer plug? Seen some there, and you've probably already got 12V there since you've done a bit of towing before...
Ben, that's a good idea.
So I would just ground it like normal and then tap into the constant power at the trailer plug?
[Just an outlet to use any 12v accessory.]
[Just an outlet to use any 12v accessory,] can get to be purdy Big Stuff Bama, especially when you say >Small Heater<.
Maybe run a 8/10 gauge fused wire from the Starter Solenoid back to one of the holes on the inside of the Stake Pockets.. to a switched plug-in box Maybe ??
Just food for R&D :dunno
:dunno The Center pin is seldom (mine wasn't anyway) pre-wired for anything :dunno
