Help Needed 16 Inch Dually Tires
Jesse East
King George Virginia
I need to replace my Dually rear tires. I learned several years ago that the 255x85x16 would fit without interference between the tires.
Who makes this size in a street version---E-Rated? Anyone know?
Thanks, Jesse east
patrickc
Ontario, Canada
I'm thinking you are going to have trouble finding that size in a E-rated tire. I know Interco tire (aka super swamper), Cooper and BFG all make 255/85's but they are only D-rated. (8 ply) Personally I have never had any problems running D-rated tires on a SRW or DRW. Just my 2c
Jesse East
Patrick
Thanks for the input. I did a little looking around and found two that are E-rated.
BF Goodrich has a T/A KM2 in the 255/85R/16 for around $200. This is an Off-Road tread, but others have used it On-Road. Its a little noisy.
TOYO has an Open Country M/T LT 255/85/85R16 for around $250. This tire was developed for On & Off-Road useage.
Cooper has a Road tire but it is D-Rated.
Im thinking I will go with the TOYO.
Jesse
Jeffro
Bloomfield,NM
Good tires
I have ran Toyo tires for year with no problems. I use them on my company and personal vehicles. The Open Country and M-55 are great tires.
patrickc
Ontario, Canada
Jesse
I'm sure you would be happy with the Toyo's or BFG's since they are both good quality tires. I have never owned a set of Toyo's but have heard lots of good things about them, as for BFG's I have always had good luck with them. Cheers, Patrick.
Jesse East
I went with the TOYO M-55 255/85/R16s. They fit with about a 0.7 inch gap between the duallys. I will have to keep an eye on them if I load her up---doesnt happen often. I put 70 psi in them, but could go to 80 if needed.
Jesse
RoyBoy
Diesel Dork
central WI
Toyo M-55's are all my brother and I will run anymore. I have 235's and he has 265's. He is on his second set and we are very happy with them, once you get past the price. :sweet
patrickc
Ontario, Canada
Jesse
Would it be possible for you to post a few pics? I'm going to do something with mine in the spring but I'm not 100% sure what. (6" Lift? 35's? etc.) I'm curious to see what yours looks like with the bigger boots. Thanks, P.
colotow
Just playin' in the sand
Tooele, Ut
I haven't been on here for a while, no time BUT I ran a set of kelly AWR 255/85R16's, i got almost 50k out of them and I've been close to 20k loaded with a trailer. they were a D rated, but the weight ratings were higher than the stock junk general E's
Bad news is, kelly doesn't make them anymore
I have a 7.5" front spring/8" kelderman airride rear lift, and I just put a set of 305/85R16 buckshot mudders on mine. they fit the rims good, don't crown in the center too bad, they will fit with no spacers, but the tires rub just a little. I have 3" spacers right now, those are too wide, but I already had theem. I need to get some narrower ones, maybe 1.75-2". Buckshots are an E rated, over 3,000 per tire gross rating as duals, i'd run them before on a K2500 and liked them
so far, they come real close to but don't hit springs or fenders in the front when turning.
I need to figure out my new camera then I can post a pic, but it looks good!
Svttim
