2000 7.3 rough running
puma
Truckee Ca.96161 USA
Hi every one, my 2000 7.3 is rough running, no codes, I changed the valve covergaskets, internal wiring and glow plugs recently,this problem was going on before that.also i changed the cps. and checked the tps with a scanner. I have heard that I can/may have a problem with the hi pop oil system, it checks ok with the scanner pressure wise. I have heard that you can get aggresive with a solvent right before an oil change? Any ideas would be great.
Regards
Regards
Stock ? Any Mods ?
Sounds like.. yet another "Air In The Fuel system" issue. You could check out a couple of current posts on the problem... and the fixes ?
I would NOT use any solvent in your OIL SYSTEM. The HPOP will suffer damage if it is not properly lubricated all of the time. Be Careful!
rammertide07
Rogersvilles, AL
Stock ? Any Mods ?
x2
When you say internal wiring....you mean the injector harness?? Did you have the injectors checked out with a scanner?
What kind of fuel pressure are you getting? I've read on another forum of a guy with a similar problem. He had the truck running and for some reason:dunno he opened the fuel bowl drain valve and the problem stopped, untill he closed it back. Maybe this was getting the air out of the system....but I dont see how since the air would be at the top....right??
rammertide07
Rogersvilles, AL
x2....probably not good for the gaskets either. And tracking down fuel leaks can be a PAIN!!!!!
Frankenstien
Frankestien
South Prairie Wa.
Food for thought, while the engine is cold... and I do mean cold, start it up run it for a few minutes, just long enough for the exhaust manifold to START to get warm. Shut her off. Manually touch each exhaust port, if you have a bad one you will FEEL the difference. Might give you a clue of where the problem lies.
