2000 p./s rough running
puma
Truckee Ca.96161 USA
I have a 2000 p/s just started running rough. check engine lite is on.
DTC codes are 1278 hi to low side open and 1316 injector circut IDM codes dectected. Any ideas?
thanks guys
Glassdude
Sonoma, CA
Sounds like your under valve cover wiring harness. They have a tendency to come loose. I'm dealing with the same problem. I hear Ford as clips to help them stay together or you can get an upgraded harness. Ford charges a pretty penny for the harness so I'm going to try an International dealer.
Mike
dMerre89
Mines doin the same thing, but only when its warm? What could this be? Injectors? Im gettin it checked by a programmer monday. CEL is also coming on when warm.
bonestroker
stroke it if you got it
In the field
mine was doing the same thing I got the clips and if fixed the prob. I took the VC off to do this plus you only get 3 clips
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
You only need 2. One's a spare.
no-red 6 0
Senioritis
southmetro MN
someone correct me if i am wrong, but wasn't there a TSB for this problem...or am i thinking of a similar situation.
2000SuperStroker
Wakefield, Kansas
mine did the same thing only 2 idm's, 1 pcm, 1 vc harness, and one new injector latter the problem was solved. If it isn't the vc harness I would do a injector buzz test and see if 8 is weak or not. If I would have put in a new injector in the first place, I would be a lot richer.
