BWard
Auctioneer
I installed my second 4" down pipe from Powerstrokeshop.com. Both down pipes are hitting the engine block as well as the passenger side floor board, making cab noise unbearable. Has anyone else had this problem?? If so what did you do to fix this?
If not whose down pipe did you use or who has the BEST downpipe??
That must be a REAL TIGHT FIT for the 5" Pipes.
Will it hurt the truck to just run a down pipe with no other pipe on until I get this resolved? I need my truck.
Thanks you guy's and girls are the best!!!!
