4 low
fly boy
panama city, fl
Recently, down here in PC beach I pulled a Chevy out of the sand. he was stuck up to the frame and was not moving anywhere. I pulled up behind him and hooked the tow strap up to the hook on the front. I put the truck in neutral and then switched to 4 low and put the truck in reverse. I rolled back a foot and I felt it engage. Well I barely touched the pedal and his truck came out with ease.
When I went to put it back in 2WD it made a awful grinding noise. I put it in neutral and then in 4 hi and then in reverse. Rolled back and then went to 2WD. This seemed to be the way. Anyone else have grind issues?
Nasty
Manitoba
my Dodge
would do that on occassion ifn I didn't get the shift just perfect....it's a 6spd. I don't think I ever had occassion to try the Fords. Recall that issue with other 4X4s I've had. Seemed they all got better with practice.
no-red 6 0
Senioritis
southmetro MN
i would say it is normal considering i have done it on at least 2 occasions.:doh:
it sounds like you are just grinding the teeth away right...
in my expert opinion:roflmao i just did not wait long enough for the internal shift to take place and changed gears too quick....i wouldn't worry about it.
georgetown texas
heck its almost impossible to get outta 4 low if yer on any kinda incline few times i've just shut the truck off which cuts the vaccum to it and dont make any grinding noise then. never heard grindin just a thunk
