6.0 issues
Niwrek
Calgary,Alberta
Hi there everyone,
I have been reading on here for a few days now, and I want to post my problem.
I have a 2006 6.0
5" turbo back exhaust
58v ficm
studded heads
egr delete
air raid intake
powermax turbo(new)
banks intercooler
My issue is I have turbo flutter under load, the truck sounds like its sucking air threw its teeth when idling. When I am not towing the problem is less obvious. I have hpop and fuel pressure gauges they are fine. I have replaced dam near all the sensors, any ideas???
This sounds like you are running with a partially clogged EGR valve. Take it out and brush it off real good and re-install. I will bet this clears it up. And :welcome4 Niwerk!
Dave :)
Term3
Edmonton, Alberta Canada
Is the PowerMax a non-variable vane turbo or variable vane type? If it has vanes it may be a problem with the hydraulic controller.
