6.0 powestroke newbie power questions
skeetrduty
oak grove mn
whats the best power programer to get without having to worry about the head bolt problems and egt temps...how to clean egr valve? i have a 2006 f350 6.0 powerstroke lariat crew cab long box.. pull a 20ft enclosed siding trailer
First off Welcome to http://www.superdutydiesel.com/ Not trying to be a smart@ss, but I wouldn't put one on it unless I had the money in hand to put the head studs in the truck. I am sure others have other thoughts on this.
And Gauges.. Right after the Head studs.
Best way to clean the EGR is to DRIVE IT.. with purpose, and be a bit aggressive with it now & then. [BUT NOT WHEN TOWING]. Limit prolonged Idling.
atk
Moderator
simcoe, ontario, canada
Welcome to SDD......
as for a programmer, SCT with custom tunes. you can get the tunes that are meant for trucks still using stock headbolts.
also as BIG JOE said, get guages......
RoyBoy
Diesel Dork
central WI
Ditto to above comments with a few additions.
You MUST get an EGT gauge installed. This can't be stressed enough.
DON'T tow with a hot tune. Follow the tuners weight limits. Tow tunes for the 6.0L are basically just slightly over stock.
Even a stock head bolt tune can blow gaskets. It's happened many times. As said, be prepared to do studs if you play.
roger2003
Milwaukee,WI
I am running the power pup. Haven't done the head studs yet but I watch my egts close and my injector pressure. Also my engine temp and tranny temp. Just be careful and don't drive it into the ground.
