7.3L Towing weight???
zax317
Diesel Virgin
san antonio/tx
I have a 99 F350 DRW Crew Cab Long Bed, Super Duty 7.3L Diesel. My wife and I are looking into getting horses. We want a steel trailer, anywhere from 2-6 horse trailer. We saw a 3 horse trailer that weighs 4300. I know I can pull this, but while looking into this stuff I wanted to know my max weight pull/tow capacity. We would be utilizing gooseneck hitch. We do not have a GN hitch yet.
Your weights are on the Driver's Door Post. There is a sticker with this information on it.
The 1999 DRW came with 3.73 and 4.10 gears, so what Dave said will
get you what you need to know. I hope you have some gages on your truck
before you start pulling heavy loads.
I have a 99 F350 DRW Crew Cab Long Bed, Super Duty 7.3L Diesel. My wife and I are looking into getting horses. We want a steel trailer, [anywhere from 2-6 horse trailer]. We saw a 3 horse trailer that weighs 4300. I know I can pull this, but while looking into this stuff I wanted to know my max weight pull/tow capacity. We would be utilizing gooseneck hitch. We do not have a GN hitch yet.
The >2-6< horse trailer part brings up another issue to concider ?
The GCVWR (Gross Combined Vehicle Weight Rateing) of your 99 F-350 DRW.
That Would Be:
A. The Total Weight of your truck, with you and the wife in it, your gear, and a full tank(s) of fuel. (GVW) Added To:
B. The total weight of the Horse trailer, the gear & tack, plus the >Known< weight of X number of Horses in/on it.
F-350, Duallys are purdy Stout.. But with Horses.. you can get purdy Heavy, Purdy Quik, when you add A & B together for a GCVW, against the GCVWR ???
:dunno
Most folks I know, that pull horse trailers, have Goosneck Hitches.
Frankenstien
Frankestien
South Prairie Wa.
Playing off of my aging memory...
19500 Gcvw - 21500 GCVW depending on options and Final Drive Ratio...
under the FWIW category... My Truck Fifth wheel, loaded with Water food and all the stuff for a long week of going away, we hit the scales at around 22K a bit over the rated weight rating, however no issues with stopping or going...
When pulling a 35 footer fifth-wheel it's real easy to hit the mid 20's
on weight. When we take off for our 3 or 4 mo trip to South Texas,
I run across the Cat Scales at the truck stop and it's around 25,000 or a little over.
mp18d
Truckee, CA
You'll be fine
Our horse trailer (4horse Trails West trailer (steel) with 3 big saddlehorses and gear for 5days at a line camp comes in right at 9500lbs. Thats well under the GCVW for your pickup.
That setup is hauled with the below SRW rig; even before the flatbed was put on and when it was boxstock. No issues at all.
And FWIW get a B&W gooseneck hitch. Have installed now 5 of the things in the last 8 years without any problems.
If you have any more ??s just ask!
Good Luck
Mike
dserge66
