thanks, been here for quite some time, will fill out info.DaveBen said:By the way, welcome to SDD wls. Glad you found us. Lots of information here. Fill out your signature so we can help you better. Go to the User PC and click on User signature and fill it out.
Dave![]()
wls said:Well I ended up finding a srw 96 f-350 d-60. Just have to freshen it up. What spring would be good to keep, for a plow install, go with the stock 250's, or a set of 350 springs. If the 350's where is a good place to get springs? Both would get a extra leaf installed. Thanks
DaveBen said:It will fit, but you will have to convert the outer hubs back to the proper offset for the stock rims. You will need hubs, discs, and all of the bearings for a standard SRW hub carrier.
RedPenguin said:All that may be true depending on how complete the axle is. If the axle comes with everything he won't need very much. What is this offset you are referring too? Remember he's talking about a front axle not a rear axle, so SRW and DRW don't make much difference.
