99 7.3 PSD Wont go in gear
AGDieselMech
MY PSD wont go anywere.... even when it is in gear.... i need help fast i need to ge to get home today
abe
AGDieselMech
Hey thanks for the welcome.... its auto.... 4x4..... its stuck in pismo...
AGDieselMech
Yeah the fluid looks good.... the cable going from the gear shifter to the side of the transmission looks great... i just went to town and came back it was running fine, parked and about 2 hours later i went to go and hook up the trailer and it wont go anywere.. im thinking it is the torque converter...
clem
N.E.Ohio
Seems the TC shouldn"t give up all at once without some kind of warning.Was it rattling at idle or searching at speed?How long since fluid and filter change?
bad_bad_bubba
The Colony, Texas
this might sound wierd but last year mine did the same thing last year and it turned out that it was a battery problem. If they are going out it can cuse some really wierd things to happen. jusy my :2c
Frankenstien
Frankestien
South Prairie Wa.
4X4..... goofy Touch Drive or Manual X-Fer Case
Touch Drive may have partial engaged and placed your X-Fer Case in Neutral. you may need to take a 1/2 socket and manualy put it back to 2 high. If the problem is you cant move your shift lever to get it in gear there are a couple of under hood fuses you need to check.
