Process to bleed air from the oil rails...... Take the main fuse out so the IDM cant fire the injectors and crank engine until you have oil coming out all 8 oil spouts on the injectors. Usually like 30-60 seconds of crank time, let the starter and batteries rest, then crank time of 30-60 seconds, rest cycle again. Three or four cycles like this will usually purge the air enough for a start. After than, plug your IDM fuse back in and go for a fire. It will run rough as there will still be air in the system, run the piss out of it for about 50 miles and it should smooth out.
