Bubba
Pulling trailer with jeep grand Cherokee, after 100 miles od light began to flash, was running flat interstate 95 south in South Carolina, I was using cruise, probably shouldn't have. pulled off interstate shut down and waited about 20-30 minutes, restarted light off, back on road, within 7 miles flashing again. It seemed to shift fine, didn't notice any speedo, but could have been fluxing not sure. This AM used my Actron OBII Pocketscanner cp9125 to read codes, comes up no codes. Actron site says the scanner is CAN Complaint. Cranked truck not flashing after 20 minutes idle. My real question is, is this Actron scanner able to read the diesel codes? Heading out to drive and return trailer see what happens?
I had planned on trans fluid and filter next week before this happened as I have not done this since buying truck ( yeah stupid I know)
I have searched forums and basicly I see where you need to check the codes, or your changing parts till ya change tranny. So I really need to know if my reader is ok for use here. Truck is used everyday, hauling trailers once in a while.
Thanks in advance you guy!
