ABS light on... VSS?
sagebel
Stock? Pfft!
Albuquerque, NM
My ABS light came on today on the way to work. The truck seems to be shifting different as well as the cruise control hunting for the set speed. I am pretty sure it is the VSS but would like a second opinion other than my own.
Scott
atk
Moderator
simcoe, ontario, canada
there should be a code stored for the reason abs light came on....but, more then likely that is your problem....
shake the front wheel bearings and make sure you don't have a loose one..
if not, probably VSS
sagebel
Stock? Pfft!
Albuquerque, NM
Fixed, VSS replaced. Parts store computer (O'Reilly's) was calling it the driveline ABS sensor. OD light never flashed.
