aftermarket gauges
melmount
greensboro nc
which gauges are the most important?
I know egt then what?
I have from factory, trans temp, coolant, oil pressure, and a factory boost, not great gauges but none the less, they are there.
i am getting an egt? i have a 2 gauge pod for now?(thanks bushpilot)
whats the next one i should have? I have room for one more. i dont have the cash to get tons of them, yet!:dunno :confused: ;tu
melmount
greensboro nc
wheres the map sensor hose? i would(i think) want to do boost from that?
do i need to drill and tap?
melmount
greensboro nc
if removd(no biggie) do i need any new gaskets or anything? i have all drills and taps i need?
gonna order monday egt and boost i want a better temp too. i am afraid of overheating, at least with out gauges.
melmount
greensboro nc
to make sure i am thinking the intake? is that the large 90 degree elbow real close to the egr valve? that sometimes you remove to clean cause of the egr?
whats the hose go to thet connects to it? make sure i am going to go to the right spot. I know this question sounds stupid
YES that is the air intake from the intercooler to the manifold. It has NOTHING to do with the EGR valve or cooler. The big elbow where I added my boost gauge fitting. You need to get a manual to give yourself an education on your truck. Ebay had Ford DVD manuals that are good.
the egt & trans gauge are the most necessary.
heres proof the factory trans gauge is nothing more than
an "idiot light" w/ a needle on it -->
LINK: VISUAL PROOF the Trans gauge is WORTHLESS
the 05+ trucks have a factory boost gauge but it leaves plenty
to be desired...not many markings and not much "sweep" so its
inherently inaccurate...if youre gonna add a boost gauge then
drill and tap the elbow (its reported that those who have not
drilled and tap'd for the boost gauge wind up w/ buzzing/noisy
gauge)
again the boost is nice to have but the EGT & Trans are more
important (no matter if you tow or not).
heres some gauge installation instructions specific to the 6.0L.
DieselManor - Installation Sheets
