Alignment or ball joints?
glassauto
Scott La
Not bad but i would have them check both sides they tend to go out together mine did along with all the tierods
clintusaf
Clint
Bossier City
Well, lools like it is my drivers side upper ball joint is bad. Which explains the uneven tire wear. And im gonna go ahead and replace the lower while im at it. I took it to a small locally owned alignment shop over in shreveport called walkers spring and brake. They seem to have a pretty good reputation and have been in buisness since 1928. They quoted me $300-$400 to replace both ball joints and align it. That seems pretty damn reasonable to me. What do you guys think?
clintusaf
Clint
Bossier City
Well, i climbed under the truck and watched him check them and the passenger side was tight as a whistle. I was kinda thinking that too that they should wear out together, but no need in replacing the passegers sode when they are tight right?
They generally don't WEAR out together. One side generally gets hammered by a rock (s) and that takes it out. Or sends it on its way to destruction.
Dave:)
jpringle83
WA
Dave:)
Or hauling a load and you find that one wonderful pothole or during highway construction the sign that says bump is right next to it.:eek:
