dzl_x_4x4
Dzl_X_4x4
On the altenator there is a hot wire and a plug with 2 wires. What tells the altenator to start charging. My altenator is good (had it tested) but not sending a charge to the batteries. is there something else I can replace?
Emergency! Son's birthday today and we all can't fit in the little dodge 1/2 ton.
To begin here is some history on my issue http://www.superdutydiesel.com/foru...gine-drivetrain/8555-altenator-bad-diode.html
My battery warning light came on, so I came home and hooked up the volt meter and tested it. It is 12.03V not running 11.43 running, 11.42 running at high idle. So I take off the altenator and take it o AuitoZone to be tested. It passed. So I brought it home and tested the continuity between the battery post clamps and the hot wire on the back of the altenator (previous problem from above) and it has continuity (not open). So I clenaed to battery terminals, charged the batteries, and about to connect everything and pray it works.
Thanks!
Dzl_X_4x4
Thanks!
Dzl_X_4x4
, thank you Lord! I hope this is the long term fix, but I appear to be getting 13.90v at the hot wire on the altenator and 13.5v at the batt's.
