backspacing question?
clintusaf
Clint
Bossier City
Im finally down to the wearbars on my POS tires. BTW, if you ever run across a cheapo tire called Milestar, stay away from them. The ones i have have a highway type tread pattern and i only got 15,000 miles out of them. they are load range D, but took them offroad maybe twice and rarely pulled with them.
What is the backspacing on the stock 2002 lariat wheel?
Im possibly looking at the Mickey Thompson classic II wheels. It says the backspacing for the 16x8 is 4 inches. The backspacing for the 16x10 is 4 7/16 inches. Im confused. Do i need more or less backspacing than my stock wheels in order to fit 315's? :dunno
wheel backspacing is going to change depending on width to keep the wheel centered over the hub unit bearing.
edit--
p.s. Milestar tires = China
where product specifications are known as "suggestions"
i found in another thread the the backspacing for my wheel is .25".
http://www.superdutydiesel.com/foru...l/20706-oem-wheel-help-asap-post187055-2.html
i'm still confused on this. what backspacing do i need to get in order to pull the wheel out of the wheel well so i can fit larger tires?
pulling the wheel out of the well is gonna cause you more problems than it solves..
the first picture is a non-artist's rendering of a neutral, or 0-offset wheel
the second is a high offset / low backset
the third a low offset / high backset
what you need to do is keep the center of load at or very near the wheel /axle bearing, otherwise you have bearing problems (ie, short service life)
clintusaf
Clint
Bossier City
thanks JL. thats what i needed to see to understand it better. so if i did want to get the MT wheels, and stay with 285 or 305's, 4 inches of backspacing would move the wheel in 4 inches?
keeping my stock wheel may be the best option then huh?
no. Four inches of backspacing would put the hub four inches in from the outer lip
clintusaf
Clint
Bossier City
okay. i understand now. had a brainfart. i need to just take my stock wheel off and measure the backspacing. i have 1 1/2 to 2 inches of space before i hit my leaf springs. think i can go 35's without rubbing?
clintusaf
Clint
Bossier City
oh and one more thing. the above post i made said the stock backspacing was .25.
thats the offset. doh!
+.25 offset means the wheel mounting surface is .25" towards the outside from the center..
clintusaf
Clint
Bossier City
learnin slowly but surely. i found some comparable wheels made by ultra. little bit cheaper.
Ultra Wheel
what do ya'll think?
anything special i need to know about getting new lug nuts?
