95bamastroked
Ok fellow SD members, I need some ideas and/or pointers in the right direction so here goes a long one:
Last Sunday I filled both tanks at a kangaroo truck stop near me (Attalla, AL). On Mon., I started having a miss (kicking & bucking). I was running off the front tank at this point and by Tues, it was down to about half. I had changed the fuel filter & drained the filter bowl(did this on Mon. eve). Looked clean so I thought: bad dirty filer. It cleared up on Tues. and I drove it all day on my job.
Wed. morning, it starts to miss again a couple times on my way to work. I didn't have to work that day so I stopped to get the air fixed first, then wanted to try and find out why it was missing. After the air was fixed, I ran it on the way home(been in the mid 90's down here!) and had to shut off the air to make it home. As soon as I had pulled away from the place that fixed the air, the truck fell on its face! I couldn't hardly touch the foot-feed to try and get it moving faster without it bucking and missing at all! Got it home, cooled it down and started draining fuel from the bowl into clean containers.
I had emptied the front tank and also found a bunch of sediment, and the fuel looked cloudy. Front tank now has clean fuel from a more "trusted" place and I am still getting sediment & smaller chunks from the bowl.
Yesterday, I drained 5 gal of fuel through the bowl from this front tank and filtered it, and returned it to the tank. Still got sediment and chunks from the bowl this way. Unhooked the inlet fuel line from the fuel pump and clamped a siphon pump hose to it. I siphoned 5-6 gal of fuel directly from the tank and filtered it on the way. Got nothing. Even poured 2 gal. into a clear container un-filtered and it was clean & clear!
I think I ended up with a bad batch of fuel with sediment from the bottom of their tanks. I am thinking that this has collected in the fuel pump, and now I am getting sediment from the fuel pump and this is also what is causing my miss. Does this sound like a good diagnosis? I am not sure if siphoning with a hand pump will pull any sediment from the tank if there is any in there. Today I am going to test this theory by pumping air into the fuel tank with an air hose to stir the fuel while siphoning. This should tell me if there is anything in the tank. I plan on changing the fuel pump today as well(wish me luck, I have read all about that job!). I will have to pull the filter bowl to change the pump so that will get cleaned out as well.
I would also like to get any information I can about what parts(and part #'s) I will need for a filter setup pre-pump so this doesn't happen again.
A little more info as I remember it: it isn't smoking during all of this, no bottom end or top end metal clanking noise, and I am ready to pull my hair out trying to figure out which is the right direction on this!!
I also had to take the rest of the week off because of this and my internet modem went out last night!! Had to hit wally world and buy another one and finally got it back last night about 11. Hasn't been my week!!
Any help, guidance, pointers, write ups, etc. will be greatly appreciated and welcomed!
Dan
Dan
