better factory injectors?
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
Bean's Diesel Performance Injectors
The stock single shot injectors were refered to code AA's. AC injectors were larger injectors used in the bigger motors like in buses and such. But they will fit in the 7.3. Not that I have any personal experience with that.:innocent
Give Bean a call. He can set you up with either new ones or re-manufactured injectors. The reman's from what I understand, he does in-house and flow bench tests them before shipping.
Adam G
Emporia Ks
If you change your injectors codes you may have to change your ficm to match.
if he stays with single shots since that is what he has now he'll be ok with the factory programming. But custom programming is required to get the potential out of the injectors.
FICM is a 6.0 computer control, all of that is done in the PCM (or with a chip) on the 7.3
Cost wise you will be better off sending your injectors to a rebuilder like Beans, Swamps, or Rosewood and have them rebuilt and modified to give you more power. I think the quality of the end product will be the same.
XOC
San Diego CA
what i do not understand though, is how they can claim 100s+ more horsepower AND better mileage. As far as I know there is no way to get more horsepower without burning more fuel, unless you magically remove all power lost to heat and friction, which I kind of doubt injectors could accomplish :dunno
Patrick Feeley
Tehachapi, CA
Contact Bean's or Swamp's or get the DIY kits from Rosewood! No need to pay that much. The guys here will point you in the right direction! If one moderates their right foot and you have a chip that's programmed for what you have, you can get better mileage. If you've got your foot in it all the time, you'll definetely use more fuel. Cheers!
I was checking these out the other day but man they are $$$$$$$
Diesel Performance
Get the injectors directly from a rebuilder, that site is selling someone else's injectors, you'll get better customer service (quicker too) from a builder not to mention better prices. They also do not mention what the core charge is that is included with the almost 4k price tag and do not tell you what it is at least as far as I went in the checkout process. Also since you are buying from a middle man I would expect a bit of a markup.
Better mileage comes from better programming that you're going to get with the injectors, provided you drive with the same foot you do now with better programming (injectors or not) you will get better mileage (presuming your foot is not on the floor board all the time), how much depends on driving style. The injectors may increase mileage if yours are worn already but that increase would be negligible unless yours are extremely worn.
Here's what I'm running in mine now from Bean's or buy new ones for around $1900. The core charge deal works out well in your favor, out of the 16 injectors I sent to bean I had less than $100 in repairs that were needed to bring them up to par for exchange. this all depends on how well the preventative maint has been kept up on the truck especially the fuel filter.
