Biod?
F250 FTW
Miami/FL
Can i just pump bioD in my 7.3 without any mods? will there be any gain from using bioD other than cleaner enviornment?
Smoother running truck, and quieter too. Carry a spare fuel filter when you switch to bio. Bio will clean out your tank in the first tank full. The junk will plug your fuel filter.
binuya
seattle wa
so I can pump it without any mod?
Absolutely. As Dave said, you might encounter filter plugging as bio is an amazing solvent and if you have any tank build up from dino, it will end up on your filter and plug it. Depends on the condition of your tank to begin with though. Didn't happen to me.
Your truck will love it. Bio will clean out your entire fuel system from tank to injectors. You'll notice it will also soften the clatter, and you'll have a sweet smelling exhaust.
Keep in mind biodiesel's BTU content is lower than dino. MPG on B100 will drop 5-10%. Proportionate drop in power. These things don't bother me since I make my own, and besides, the benefits outweigh the negatives for me.
F250 FTW
Miami/FL
How do you produce your own? You bought those tanks and setup to do it from veg oil?
binuya
seattle wa
I have a 55 gallon drum processor I made. Plans and procedures all over the web. I have been making it for over a year now. I have a few small volume restaurants where I have parked a barrel for them to dump their used oil.
It's pretty much a hobby for personal use.
F250 FTW
Miami/FL
Was it expensive to make the processor? Is it too tedious to make the biodiesel sorry if I ask lots of questions it just that this caught my attention thanks
binuya
seattle wa
Cost me maybe 250-300 bucks, plus I had a lot of parts lying around. Kinda' depends on what your abilities are with fabricating, sourcing out parts etc. Actually, the most expensive parts were the ball valves. With my set up, I needed 9 of them. Usually 6-9 bucks a shot. Check out 'how to make biodiesel.org'. Great place to start. Another thought, and above all. Make sure you secure an oil source. Without it, your dead in the water.
